Re: Merc pinion tool
If you are only replacing bearings, gears or shafts, just keep track of the exact placement of the shims while disassembly and make sure to replace them in the same position and you won't need the shimming tools as the shims only match the housing to the machined parts so if the housing is not replaced the shimming will be correct.
