merc prop 48-832828-C1-17 ?
pikiewicz
Purchased a 24ft Larson and I couldn't find any size on the prop but I did find the following numbers 48-832828-C1-17. Any ideas on the size and pitch?
Re: merc prop 48-832828-C1-17 ?
i'd assume that it is a 17 pitch prop. i have a merc prop and the last two digits are 21. and it's a 21 pitch.
hope that helps
coolguy147
quicksilver prop. yes the last 2 digits are the pitch. same for my prop.
Ayuh,... It's 17" pitch,... Diameter's pretty much irrevelant...
pikiewicz
Thanks for the reply's. What do you mean when you say the diAmeter is irrelevant? Does the diameter matter? I think it is 14 1/2.
steelespike
Diameter follows the design and will vary depending on the type and brand of prop.
If the prop is designed for the application the diameter will fit.
Occasionally clearance to the trim tab is close and a flattened tab is selected to be sure the prop will clear.
