Merc/Quicksilver Bow up-Bow down switch..where to find a new one...
SSSuper83
My UP function has puked..have to trim up with the trailer button. Anyone know where I can find a new one?? Mid 80's Quiksilver control..trim switch up near the top of the handle. other controls work great.
Fun Times
Re: Merc/Quicksilver Bow up-Bow down switch..where to find a new one...
Keep in mind that you may have a bad trim limit switch that is mounted to your gimbal ring assembly, See number 12 in this link below.
http://www.mercruiserparts.com/Show...&bnbr=50&bdesc=GIMBAL+RING+AND+STEERING+LEVER
If that switch is bad, then your trim up button would be inoperable, But the trailer button will override the trim button.;)
stonyloam
Boat tech is right. There is a pretty good chance that there is nothing wrong with your control handle switch. Your symptoms are common for a malfunctioning trim limit switch on the outdrive. Try this: Back by the transom, locate two black wires going into a connector with a purple/white wire and two blue white/wires. Unplug the wires and jumper from one side of the connector to the other. Try the trim. If it works your problem is the trim limit switch or the black wires going to it. If the switch, it may just need to be cleaned. Do you have a manual? Good luck.
SSSuper83
Thanks guys. Limit switch is bad. Guess I will be using both buttons as I just got her back together and need to get on the water. And yes, I know where the drive is at ALL times. I'll be careful with her. Will replace it in the fall.
