merc starter
tystick
where can i view the correct starter for my 1990 4.3L merc. engine. The boat is not avail. but I need to get a starter.<br />thx robert
Don S
Re: merc starter
Mercruiser part number 50-864340A 2<br /><br />
tystick
Re: merc starter
don, <br />It seems various suppliers reference different manuf. for starters. Seirra, arco etc. Is there a site where i can cross reference the mercruiser part number?<br />thx robert
Re: merc starter
The Sierra #,+ the NAPA # is 18-5913.........
tystick
Re: merc starter
Does this starter #IBS5323M<br />also cross-reference?<br /><br />Thx Don,<br />BTW, I have a nephew in Tellkeetna (sp?)
tystick
Re: merc starter
I have to diy job on this starter in remote location. Has anyone done the merc 4.3L starter job? I am wondering the best way to get leverage/access to the mounting bolts.<br /><br /><br /> What is the socket size required for bolts on starter?
Don S
Re: merc starter
Socket size is either 9/16" or 1/2" depends on which bolts were installed.<br />The main nut for the battery cable is 13mm. The small terminal is 5/16" (8mm).<br /><br />Access depends on the boat. I have one that requires an engine pull to even touch the starter, some are a 10 minute job for total R&R. Then there is the rust and corrosion thing.
tystick
Re: merc starter
These are supposed to be a cross-reference chart for the 18-5913...<br /><br /><br />The Sierra # matches yet not sure why the merc #s do not?<br /><br />CP6562 Replaces:<br /><br />Mercury Marine: 50-806964A2, 50-806964A3, 50-807904A, 50-812428A3, 50-812604A, 50-82230A2<br /><br />Volvo: 3850764-4, 3854751-9, 3856004-1, 3860764-4<br /><br />Sierra: 18-5913<br /><br />Arco: 30450, 30470<br /><br />Marine Power: 0174-000<br /><br />Original Delco Number: 90000821<br />Robert <br />Boat in ACK
Don S
Re: merc starter
Mercruiser superseded the number, don't have a clue why, may be a new method of packing or a new supplier, or a starter change. Sierra, however, probably didn't notice and hasn't found out what changed. So they don't show the new number. It's not Mercs fault, they show their new number.
