merc switch box help
leserz
had spark b4 i replaced starter rope on a 1974 # 110 9.8 hp now none at all. think it's a type 3 ign. molded black box, epoxy back, wire's molded into it. 8 wire. got out my ohm meter. every thing checks out under fly wheel. did coil test ohm meter only each one was ok. dont have a amp guage to use. cleaned all wire conections. found one wire from switch box to top cyl. was broken off at coil terminal. replaced it.any way to check a switch box back yard style ? any clue how much one would cost ? dont think its worth spending to much money on. any idea's ?
Hooty
Re: merc switch box help
I don't know if your's is the battery cd ignition or not. If it is, here's a website on troubleshooting it.<br /><br /> web page <br /><br />c/6<br /><br />Hooty
leserz
no battery. its a manual start.
hondon
You should expect to pay 200 + for that switchbox.Not a cheap item.Sorry.
