bowler
- Nov 9, 2009
- 282
hi all,
had the boat out last week on our easter break and it ran well. i noticed around the last day that the temp guage died (wouldn't reg above 100). up to this point it ran about 120 which had never bothered me (better cold than hot i reckoned?) but i've read around the forums and research suggests that the t-stat may be stuck open. would it be likely that it had been failing and has now finally given up the ghost? i believe that the running temp should be around 150-160. my guage never went above 120 even under load at WOT.
my boat is 60 miles away so can't check until the weekend. is this most likely problem if the guage has always read low? i'm thinking of ordering one now so i can have it at the weekend, replace if necessary and get the boat out!
cheers in advance,
D.
cheers in advance,
D.
