Just checked the timing (at cranking speed) on my '81 Merc 18. Timing light shows about 4 deg too advanced at WOT (29/30 BTDC instead of 25 - 3 punch mark on flywheel). <br /><br />Trouble is the trigger linkage is as short as it will go and I need to shorten it to retard the timing. Is there anything else in the trigger area that could cause the timing to be too advanced?<br /><br />The motor starts and runs fine with no detonation under load.<br /><br />Thanks in advance
