merc trim HELP!
toddbsss
problem is trim goes down no problem but will only go up once and awhile. The only way i can trim up is to short the slynoid on the trim motor when it's acting up. this system uses three buttons one down,one up and one for full up which works when you press both up at the same time.what can the problem be.The boat is a 1980 tempest with a 140hp inboard.
Re: merc trim HELP!
The wires going to,+ coming from the trim limit switch are Broken......<br />Either By-pass them, or Replace them....
