Merc V6 EFI backfire while starting up
Ebola
My engine backfires through the throttle body when I crank it up. Does anyone have any suggestions on what might be causing this? The motor has been sitting a while and I don't really know what shape the valve train is in. I will be pulling the motor for a rebuild and would like to have as much info going in as possible.
Thanks,
E
farmer9009
Re: Merc V6 EFI backfire while starting up
Timing being off is the first place I would look. Spark plugs wired correctly also.
Ayuh,... Bad gas, it's Lean...
Ebola
Gas is new, it only backfires with one pop when turning over before starting, maybe twice. From what I've read, it's a timing issue or maybe a plug wire arcing. Just wanted to see if these motor had a tendency towards one or the other. thanks for the replies.
