I am fighting with a strange flooding problem with a rebuilt mercarb 2BBL. When cold, the engine starts and behaves itself and accelerates fine and good RPM at WOT. After decelerating and then intentionally shutting down the engine and sitting on the water, it will not start and fuel is dripping onto the throttle plates. I can eventually get it started again and it will run fine until the next time a stop the engine. Here is the list of things that I have done so far:
- Rebuilt and cleaned carb
- New spring-type needle assembly
- Adjust float level (14MM) and float drop (27MM)
- Adjusted accelerator pump rod
- Corrected throttle cable length
- Measured fuel pressure (5psi or so)
- Installed fuel/water separator
- Replaced spark plugs
- Timed engine
No joy. Should I try another new carb? My original OEM carb was model 807534
Frustrated as all get out!!!!!
- Timed engine
