Mercarb brass float upgrade
Kubaat3lover
Anyone replaced mercarb float to brass one? I will need rebuilt and wondering about Brass float upgrade from Mikes Carb parts .
I heard some bad review about this upgrade but dont know why
Thanks
alldodge
Brass should be of no issue so long as it doesn't spring a leak
Composite ones will soak up fuel over years and get heavier
Brass ones last forever so long as they don't spring a leak
Old school were always brass and hardly ever an issue, and if they did leak, you could empty them and solder/braze back up
Do note that the settings for composite and brass can be different heights
Scott06
I did this on a mercarb for a 3.0, was not issue to install. If you look at where The factory manual tells you the measuring point on the float to set the float level - their is no compareable mark on the brass float. So as AD said the float level is essentially different. Maybe you could use the float level off a Rochester 2 bbl which is what the mercarb was developed from. The brass float supplied For the mercarb is actually from a rochester 2 bbl...
bottom line It works fine. I bought mine from mikes carb shop I bet they can tell you how to set it up properly.
