Mercmonitor and analog trim sender
divljan
I have Mercruiser MAG 350 engine with Bravo Three drive on my 2012 Regal 2300 with analog gauges.
I have purchased and installed (by myself) level 2 Mercmonitor by simply plugging
the smart craft cable to engine,and to mercruiser junction box and Mercmonitor,and
planing to hook up Garmin GPSMAP 421s over NMEA 2000 to Mercmonitor in order to
have all info on fuel economy on my mercmonitor and gpsmap.
I now have reading on fuel consumption,temperature and stuff,and gonna get info on
speed over ground via GPS,but i have no info on trim.
Im not sure is trim on my engine digital or analog,the gauge is definitely analog,
and trim sender is connected via 2 wires to the gauge.
Is there any chance to connect existing trim sender to smart craft junction box,engine or something like that to get trim level on my mercmonitor? Is there any converter assembly
for converting analog trim sender to digital,and does 2012 MAG 350 have analog or digital trim sender by default?
alldodge
Re: Mercmonitor and analog trim sender
:welcome:
Did my previous post answer your question?
divljan
:welcome:
Well not exactly,
I was hoping someone had the same problem,since I have read something like it is only about wiring,and that bravo three comes with digital trim sender already.
And I have found some trim sender converter
Mercury Boat Trim Sender Conversion Module Inst. Kit | Great Lakes Skipper
but I can find no info about is this used to convert analog sender to use with digital instruments,
or used for adapting digital sender to use with analog instruments.
It would be much easier and cheaper to connect converter to the analog sender,than to install a new digital sender
