MerControl high idle lever issues
Jdevon_14
Just put new cables on my mercontrol box. Took it out to the lake and now everytime I try to put it in forward the high idle lever moves up. It does the same when you go from reverse to neutral. Just wonder what I did wrong.
Chris1956
OK, a wild guess. If you switched the cables, the throttle cable will move first, speeding up the motor, when still in neutral.
