PaintedStallions
- Apr 20, 2011
- 8
I have a 1971 StarCraft with a Mercury 850 85 hp. I can’t get the engine to rpm up when I shift into forward. As a matter of fact, the forward lever will literally go to 6 o’clock position with no rpm worth mentioning. It even stalls when I put in forward. Reverse is fine. And the neutral warm up lever doesn’t raise the rpm’s. The rpm’s do raise just a slight bit in forward just a hair above idle speed. Is there something broke in the controller you think? Is there a way to adjust the cables?
