mercruis 140 alpha 1 mystery part in exhaust
djvan
I found this part in my exhaust wedged up against the exhaust ports that exit the lower ports at the bottom of the transom/gimble ring. Is this something anybody recognizes or is it something that fell in when torn down previously? 1986 Mercruiser 140 hp, Alpha one, gen 1, raw water cooled. Any help is greatly appreciated. This forum is excellent, I'm learning so much.<br /><br />DougV<br /><br /> http://www.geocities.com/djvan00/boatpart.html?1062806344616
FreeBeeTony
Re: mercruis 140 alpha 1 mystery part in exhaust
looks like a piece of the flapper. you should check and make sure you have a full one installed. it should be installed at the top of the exhaust tube. it prevents water from being washed back into the exhaust from the transom.
djvan
Thanks, Where is the flapper located exactly? Someplace in the exhaust piping I know but is it near an elbow or something? Is it hard to change?<br /><br />DougV>
merc 140 pontoon
Is the piece made of rubber? If so, it is half of your exhaust shutter (flapper). The Merc shutter design is good--it breaks in half and the halves usually blow through. The OMC shutter design usually fails in one piece, and sometimes blocks the exhaust downstream.<br /><br />The shutter is #7 in this diagram. The mount #2 is held in by screws #3 and nuts #4, but in older exhaust elbows the mount #2 was riveted, so you may have to drill out the rivets and replace them with the right screws and nuts.<br />
<br /><br />The shutter is #45 in this diagram.<br />
<br /><br />I will be installing a new shutter in my 1974 Merc 140. I have the manifold, riser and exhaust boot off. You could get access by removing your riser and boot, but you may not be able to get the riser off without pulling the manifold. Separating the riser and manifold can be tough. Don't pry, or you'll crack one of them.<br /><br />A mechanic told me to dab the ends of the new flapper metal rod with silicone, otherwise it will rattle.<br /><br />Good luck.
djvan
The piece is metal. I will be investigating further this week. Thanks for the info<br /><br />DougV>
