Mercruiser #1 trim limit switch?
fishrdan
I found the insulation of the trim limit switch wires is hard/cracking and missing in places, so I need to find out how to replace the switch. After looking around for online manuals I didn't find any of them that referenced this old style switch on my 72 #1 drive (S/N 2901044). Here's a shot of the the upper transom assembly from outside the boat.
I can see the cover/arm that contacts the switch, but don't know what is involved in replacing the switch, all the manuals I've seen reference the new style switch. Looks like it's going to be a real bear since from what I can see, the bell housing needs to be removed to get enough access to remove the switch.
I haven't noticed problems with the switch,,, except for 1 time a few years ago the drive wouldn't go down while launching the boat.
What are the ill effects of jumpering the bullet connectors and bypassing this switch? Or am I stupid for even asking that question...
Don S
Re: Mercruiser #1 trim limit switch?
I would bet that 99% of those older one drives out there have the system bapassed or just plain don't mess with it and use the tilt button to trim up.
If you trim up to high, the rpm goes up and the speed goes down.
Trim is a constantly changing adjustment due to wind and waves, and soon you can feel and hear the proper trim and won't need that trim limit switch at all.
JustJason
I'm the 1% then... coz i've got one sitting out in my yard and it works.
The switch is a pita to change... and not really worth it.
BTW fisherdan, that switch only limits trim up... doesn't have anything to do with the drive going down. theres no need to jump the connection or anything like that... just to trim out push in on the top two buttons at the same time on your trim control switch.
fishrdan
Cool deal! That's one less thing I have to worry about.
This boat has had ??? (only God knows) PO's and I've had to fix lots of hacks.
I know the 3 button trim switch is supposed to function different than it does as I only have to push 1 button for up and down, don't have to push 2 buttons at 1 time to get the drive to raise or lower,,, or how ever it's supposed to work. At one time someone put a Scotch Lock (the scourge of all electrical problems) across 2 wires in the trim system. I haven't looked to see what the affecting switch does, but I'm sure it has something to do with locking out the useless trim button...
ziggy
pushing the one button for up i'd think means it's bypassed. i'm in the 99%, mine don't work, i use tilt w/ caution., middle and top button for up. anyways, that ain't what i wanted to put ya onto....
this is..... http://forums.iboats.com/showthread.php?p=1520997#post1520997
check out hm's post #5. 1+ gb download, assuming it's available, seems like it is.
JustJason
bottom button is for trim in
middle button is for trim out
top + middle button for same time is tilt up.... or trailer.
ziggy
get the service manual while ya can. when ya got a service manual for yer rig, then.... yer hip, if ya can dig it........
fishrdan
Sheesh, how long does it take for that bad boy to download (1.5MB DSL)? I've tried to get it on several occasions and stopped after a few minutes of download circle thingy going around, and around,,, and around,,,,,,,, and around.................. got too dizzy staring at the circle thing and had to cancel the download before I yaked :D
ziggy
i ain't the computer wiz by any means. with cable broadband, it locks up my puter, can't do anything while downloading it, + took 20+ miin. round abouts to down load it...... wait and let it loadz.....
fishrdan
Wholly molly, going on an hour and the manual still hasn't downloaded :eek:
Maybe I should quit monkeying around on other sites while it's doing it's thang...
Ayuh,......
Just spent the last 2 Hours,......
Roadrunner cable connection...........
'course,... That included saving a copy to the harddrive,............;)
Donno if I even Dare to open it to see if it's all there,.....:rolleyes:
Does anybody know if these files can be loaded onto a DVD,... Package says DVD+R, 4.7GB,....
I know my 'puter does burn DVDs....
Otherwise I guess I'll need to buy some CDs....
ziggy
yep, me too...
i just did that, but got dvds. the file i want to transfer is 4.06gb mostly pdf files....;)
Yes, it does work putting them on DVD. That's how I saved all mine ;)
how did ya do this? do ya have a programs of some kind? when i try to c/p it. the computer gives me some kinda error message, sorry can't remember what it said as last try was a couple days ago... but so far i've been unsuccessful in transferring to dvd..
Ziggy,.... I've got a program on my desktop that came with my 'puter,... Hope it works,...
Don,........ You da Man,..... I'm onto that 1 too....
I just Wished you'd made the comment to me sooner, back when the backdoor was Wide Open,....
I still slap myself silly with the "Duh" moment, of not saving All of them to disk........:rolleyes:
I'll be back in a Few hours,.........:D
Don S
Look what all I made work! Have fun :D
Ought to keep ya busy for the rest of the weekend.
Service Manual #1 1963- 1973 All Engines and drives
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/01/cover.pdf
Service Manual #2 1974 to 1977 All Engines and drives.
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/02/cover.pdf
Service Manual #3 1978 - 1984 All engines
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/03/cover.pdf
Service Manual #4 1978 to 1982 120 to 260 Sterndrives (aka One drives)
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/04/cover.pdf
Service Manual #5 1978 to 1993 TR - TRS outdrives
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/05/cover.pdf
Service Manual #8 1985 to 1989 Merc Marine 4 cyl (Newer 470's)
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/08/cover.pdf
Service Manual #9 1985-1988 GM V8
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/09/cover.pdf
Service Manual #10 1985- 1989 GM 4 cylinder (120-140)
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/10/cover.pdf
Service Manual #15 1989-1982 GM V8
http://www-alt.mercurymarine.com/mnetdata/SERVICE/CRUISER/Servmanl/15/cover.pdf
Don,.... The manual #1, cover says book 1 of 2,.. sections 1 thru 5...
The table of contents to the left of my screen lists 7 sections,..
Is this file actually Both Books of the 2,..??
And,.....
Your Right,....... I'll be burning All Weekend now,......
So much for floating the boat tomorrow...........:D
Don S
Yes, it's both books. Same with Manual #3
JustJason
shoulda got them all while you could :)
