Greetings,
I have a 3 Buoys SunSport Houseboat with an Merc 120 (1986). The gear shift is electronic. When switching from neutral to reverse and back through to forward, the voltmeter on the dash drops to 10 and there is a delay in switching gears. At times, it won't switch out of forward and the voltage draw on the meter stays at 10. Looks to be under heavy load. Any suggestions? I hooked up another 12 volt battery under the helm, right to the voltmeter, with a switch, so that I could boost the power. It has helped a bit, but then sometimes the engine quits when changing gears. Thanks.
