Mercruiser 120 vs 140 block
mmoenter
Right now I've got a 96 3.0LX with a cracked block. I know everything else is in good shape (head, exhaust, carb, etc). I can get a complete late 70s 120 for cheap and was wondering if the blocks were similar to where I can swap my good parts to it or if I need to find a 140 block. Thanks!
Re: Mercruiser 120 vs 140 block
Ayuh,... There'll be differences, but nothin' that can't be overcome....
mmoenter
Do you know what the bigger (more challenging) differences are? I'm looking for a rather straightforward project of swapping the head, manifolds, carb, etc to a different block. Thanks
Ayuh,... Right off the top of my head, the Coupler is gonna be different, 'n the Flywheel...
The crankshaft bolt pattern changed around 1990 or so...
mmoenter
The coupler & flywheel can be swapped from the 3.0, correct? If I kept the crank/pistons from the 120 would I run into any problems with the head?
No,... They WON'T fit....
The head shouldn't be a problem though...
mmoenter
Ok...thanks...so if I'm reading this right, the SIMPLEST thing to do (besides buying a new longblock) is to find a 140 block?
Ayuh,.... Of the Correct Vintage, yes...
mmoenter
I'm probably beating a dead horse here (and I apologize) but I came across a nice looking 1978 3.0 block for the right price ;). Would I encounter the same problems (coupler, flywheel, crank) or would my parts swap into it? This would be a bare block (no pistons, crank, etc...just block and crank caps).
Ayuh,... Same deal,... Not really any good to ya....
Look for a Long block, post-1990....
