Guywiththev-164
- May 6, 2019
- 7
Ok guys I need serious help I have a mercruiser 140 3.0, everything started about a year ago, I took the boat out one day it ran fine, I tried to take it out the next week and it fired up but as soon as I tried to give it gas it dies so I took it back home thinking it was the idle/air mixture screws and I re adjusted them and it struggled but it fired up one time it ran for about 10 seconds and it died so I set it aside for about a year and I just bought a brand new carb that has been bench tested and it was basically a plug and play part so I put it on and went to fire it up and I got no spark so I thought it was the coil and I replaced it and I still got nothing so I cleaned the point in the distributer cap and I received spark but it seems weak usually blue or white spark is seen but this spark is orange but i don’t know that there’s a big difference because a lot of people say a spark is a spark but anyway I’m getting spark now and I know I’m getting fuel, I did not replace the distributer cap the condenser or the points on the ignition system. When I try to fire it up it turns over and then stops mid turn like it gets hung up and I smell the gas being burned so it leads me to believe it’s the distributer cap because I had a 2005 gmc truck that had a v6 and it had and ignition with the distributer cap and it did the same thing and I was stuck on it for weeks, the truck turned over and stopped like something was hanging it up I don’t remember if I was getting spark out of the truck but it sounded like it wanted to fire up so I turned to the internet and found something similar and the guy replaced the distributer cap and it fired up so I did that same thing and my truck fired up so I’m not sure where to go from here much help needed thanks in advance
