Alumarine
- Feb 22, 2005
- 3,739
I need some help and I'm stumped!
Yesterday cruising at 3700 rpm just fine and rev's started to go down like I was running out of gas.
I brought it down to 1500 rpm and was able to go 1/2 a mile to a dock.
As I approached the dock and brought the throttle back it died.
I'm testing this on land now.
Checked fuel level and had plenty. No water in fuel.
Fuel is getting to carb
I can start it in neutral if I give it lots of throttle and have to keep it at 2000 rpm.
If I try to reduce the throttle below 2000 it will die.
Compression is good. Plugs were black but normally they are a good color.
Well maintained. Ignition components have 30 hours on them.
Rebuilt the carb a few years ago and have put on lots of miles since.
At 2000 rpm it runs rough.
Here's the strange part. If I pull off any plug wire the revs go to 2500???
I've enclosed a picture and fuel is coming out the hole that's circled?
thanks
thanks
