I have an 80's vintage Mercruiser 140 with only 45 hours on it.<br />It was last run in 1987.<br />To get it running again I changed oil, cap rotor points, condenser, lower unit gear lube, drained the gas tank, cleaned carb. The carb was really gummed up! My cleaning of carb consisted of removing the top cover and cleaning float area, removing the two brass jets that exit the bowl and lifting the brass tube section thats held down by four screws. After doing this the unit<br />ran. Good Idle and smooth rev in neutral.<br />On the water will run at no wake speed ok<br />when I put gas to it it dies immediately.<br />Any recommendations? Thanks in Advance
