mercruiser 140 fuel prob.
bid2ask
my engine was running great about two weeks ago and i have not tried to start it till today. it would not start, i have spark, buti think im not getting enough fuel, i poured a little gas in the carb and she fired right up, but died in about 2 seconds. i recently changed the fuel water seperator, any other ideas on what could be wrong?
jeff13601
Re: mercruiser 140 fuel prob.
Could be the fuel pump. Take the gas line off the front of the carb and slip it into a plastic bottle. Crank over your motor and see if there is a good flow of gas
Don S
What engine is it? Please be specific.<br />If it's carbed, are you trying to start it like and EFI engine? If so it ain't gonna work my friend.<br />You need to pump the throttle once to set the choke and squirt some fuel into the engine from the accelerator pump in the carb.<br />If you did this, you could have a bad accelerator pump. or no fuel in the carb which could be because of a bad pump, plugged filter, or faulty carb. Has it been tuned up lately?
bid2ask
don, its been tuned up about a month ago with points, rotor, cap, wires, plugs, wires, last year the carb was bought new, fuel seperator is new also, it ran awesome 2 weeks ago on the muffs, is there a way to check the accelerator pump? if i disconnect the throttle linkage and pump the throttle i see very little gas go in the throat of the carb.
bid2ask
i'll check the fuel pump tomorrow, should there be a steady stream of fuel when the engine is cranked
jeff13601
It should pulsate fuel from the line. Make sure you put the end in a bottle. You will know if it is pumping. I had a simialar problem that you are having and I took my line off at the tank and filled the line with gas. I also cleaned and lubed the pump so I am not sure which did it but it worked after that
bid2ask
no gas while cranking at the carb with the line disconnected, i cranked it for about 15 seconds 2 times, think its the mech. fuel pump?
jeff13601
Take off the gas line on the gas tank side of the pump, left side of pump while you are facing it, and see if it has gas in it.
jeff13601
If there is no gas take the gas line off the top of the gas tank. There is a fitting there with a valve that stops the gas from going back into the tank and keeps the line to the carb full. Take a very small funnel and slowly fill that line full and see if it stays full. If it does, hook the line back up to the tank and turn it over and see if the pump pushes it through. You could also be stupid like me. I took off the rubber line at the pump and layed down and sucked on it until gas came and I almost choked to death. lol. Your prob sounds just like the one I had and I almost wasted 140.00 on a new pump
bid2ask
got it runnig guys, i cleaned the carb filter, and changed the filter on the fuel pump, put a little gas in the carb, and she fired right up, i had it running at around 1200 rpm's for around 20 minutes. thanks for all your help guys
j.barker
i think i have the same problem,4.3 omc .. it will start and keep running for about 3 min. then just dies, it will start right away but reoeats this,, could this be the same problem? fill gas line?
jeff13601
If she is running for 3 minutes then it is something else. I think you should check your filters and water seperator if you have one. When it quits will it start right back up and run for 3 minutes again?
j.barker
no and you must be refering to water sep? going to check gas flow thru carb line here shortly and im goin to put this to new post 4.3 engine stall
j.barker
yes , new at this i/o stuff, changed the filter (canister type) checked carb. inline no filter there. any others? dont know about water sep. please help,, ready to go
jeff13601
There is a filter where the gas line goes in the carb. While you have the line unhooked, put the line in a plastic bottle. turn the motor over and see if there is a good flow of gas. Is there any thing on top of your fuel pump? Also how long does it run before it stalls again?
Haut Medoc
Post your own thread and you will get better results.
downriver
I do n't have gas going to the carb, so I should remove the line from the fuel pump, use a funnel and pour gas into this hose until full, is this correct?? then, if it stays full, hook the line back up to the tank and turn it over and see if the pump pushes it through.
ziggy
no
ya need to start a new thread with your info in it instead of resurrecting a may 05 thread. many folks willing to help. but they need your issue, not someone elses... check this out. http://forums.iboats.com/showthread.php?t=220416 it'll help ya put relevant info into your question so everyones hip to your problem......
