jackball42
- Apr 2, 2011
- 76
1977 Mercruiser 140. I noticed this weekend that my prop was a little loose so I took it off and found the thrust washer had spun on the shaft. The thrust washer is the old stainless part and not the new brass design. I am using a Michigan Wheel prop.
I assume that because the washer spun on the shaft it made the hole bigger and is causing the washer to sit lower on the taper. Will a new washer fix my issue? There is about 1/16 to 1/8 inch of play in the prop. Should I replace with a Michigan Wheel washer or will the Sierra part from IBoats work fine?
What causes the washer to spin independently of the shaft?
