Mercruiser 3.0l 140 1986 with Alpha one aligned, greased with new gimbal bearing and fluids.
Project boat. Engine was torn down; carb rebuilt, fresh fuel and filters, plugs changed, points cleaned, dwell adjusted, timing and rockers adjusted and rechecked. Running without flame arrest.
VID 00000008 - YouTube
I'm stooped. Unless the back of the flywheel housing shield needed a gasket and is rattling or slight oil overfill.
I can't figure out what this noise might be.
It seems to be predominantly mid range. Noticed I get a very very slight hesitation before top speed on wot at the top end of the rpm range.
Your guesses are greatly appreciated,
Rick
Rick
