Mercruiser 140 with 3.0 overheating
ggautney
I have an old 1970 Mercruiser 140 that is overheating when I am idling but is fine when at higher rpm's any suggestions?
rogerwa
Re: Mercruiser 140 with 3.0 overheating
Classic presentation of a bad impeller or waterpump problem.
That is where I would start.
Don S
In a boat, the impeller is the first place you start on any overheat problem.
ggautney
How big of a job is it to change the impeller and is it the water pump that sits directly on top of the motor where all of the hoses come into and go out to the motor? Thanks
D
DJ
Guest
The water pump is in the drive. Don't attempt it without a manual and a strong back.
