OK I have a very strange problem.
I have a boat that has been sitting for a few year that has not been started. It is a 1986 mercruiser 140 3.0L.
when I turn the key, the engine rotates just fine. however it just sounds like an engine that has no spark as all. I spray starter fluid in the carb and it makes no change. I have removed all spark plugs and turn the key, the engine rotates and I can see all 4 spark plugs sparking. The spark plugs are black (cold Fouled) but they are still creating a spark I can see in the daylight so that should be fine.
I have checked the firing order and it is set to 1,3,4,2 with point 1 pointing to spark plug #1. But here is where it gets weird.
I remove spark plug #1 leaving 2,3,4 plugs in the engine. When I turn the key, the engine rotates, but then almost acts like it wants to start every 4-5th rotation but never does. When I pull plug 1&2 leaving 3,4 installed, it acts like it wants to start every 3-4 rotations but never does. When I put all 4 spark plugs back in the engine and try, it acts like it wants to start for a minute or so, but then goes back to just rotating with no signs that it has spark at all.
Has anyone ever seen or heard of this before?
Any help would really be appreciated.
