dirtcrew51m
- Oct 31, 2022
- 3
Hello, new user, long time reader, 88 Mercruiser 165 4cyl, will try to make it short, acquired a motor, dont know history, tried to fire it, seems only one cylinder trying to fire, checked points, cleaned plugs, put new wires on it, same thing, noticed oil was starting to become a milkshake, figured head gasket, pulled head, gasket was oil and water wet around #1 and 2 cyls, walls still have x hatches in them, also when cranking the crankcase was building pressure, installed new head gasket, cranked engine same thing, again pulled head, gasket is wet around the same area. I know how durable and basically indestructible the 460 head is, I had them in my street motors. I did put a straight edge on the block and there seems to be a hair high between 3-4 cyls. Im thinking the dreaded 470 warped block syndrome. My boat now has one of these motors so I am familiar with rebuilding it.
