I narrowed my problem down to a fuel issue.
As long as my boat is out of the water the engine runs smooth. Low revs and high revs. All seems fine as far my knowledge goes
Once the boat gets in the water (sterndrive submerged) the engine dies due to lack of fuel.
When I manually add fuel in the carb or use the accelerator pump I can keep it running.
Im sure I have fuel in the carb, accelerator pump provides a nice jet.
But seems like the engine is not drawing fuel once in the water.
The only link I can make is because of the fully submerged exhausts.
So I guess there is a link with the back pressure of the water on the exhaust and lack of fuel. Could this be?
Could I have a vacuum issue that only makes a difference once stern is submerged?
Any suggestions on what tests I can do to come closer to the root cause?
Thanks again for all the help on this forum. I really hope I can get this boat back alive...
