So I replaced my points system with a Pertronix Ignitor 2 system. The engine runs great once it is running. My issue is that it seems harder to start than it was in the past. Before it was replaced, pumped the throttle twice and hit the key and it started immediately. After install of ignitor 2 I seem to have to crank a little to get it to start. Timing is set at 6 degrees before TDC and carb is set correctly. I think a read somewhere that ignition timing needs to be set at 4 degrees before TDC after Ignitor 2 is installed, but I can't find where I read it. Any help would be great.
