Mercruiser 165 IL 6 electronic conversion kit
Status
Not open for further replies.
popey
hi there,
my 165 IL 6 has a electronic (ignition) conversion on it. What exactly is the advantage of it?
Best Regards,
popey
smarks
Re: Mercruiser 165 IL 6 electronic conversion kit
Easer starting, less mainentence (points Adj, setting dwell). I think they idle a bit smoother and are more respondsive. Just my opinion
Steve
Bt Doctur
more expensive that points, go-no go type system.even bad points will create some spark.
Previous owner didnt know how to install and maintain them.
HorizonblueDK
I have installed electronic conversion kits (incl new coils) on a pair of OMC 165s. The idle has newer been better. With the old points, they shouldn't get below 700-800 rpm, otherwise it felt like they could stall at any time. (new points will off course had helped here) But now they run like an electric motor and can go down to 500 rpm.
Throughout the rpm range, the engine runs more smooth, I think.
The kits came from "hot-spark". They are very easy to install, no external box, it is all hidden in the distributor. Two wires, adjust timing, and you are ready to go.
Off course, well adjusted new points makes an engine run great, but I believe that system is outdated.
Electronic ignition newer wear out and requires no manitainance, great.
antsmands
hi there,
Best Regards,
popey
I put electronic ignition on my 3.0 and it responds much, much better. Better starting, idling and runs smoother at rpm. No adjustment to points and dwell. Easy to install. Worth the expense.
Bravo
Anyone have the part numbers and where I can get the conversion kit for my '69 Wellcraft with the 160 hp L6 mercruiser? I'd be really interested in getting rid of the points ignition in there.
HorizonblueDK
This is the kit I installed on two OMC 165s
http://cgi.ebay.com/ebaymotors/Elec...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
And a new coil. (forget about reusing the old coil)
http://cgi.ebay.com/ebaymotors/50-0...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
You will not regret scrapping the old stone-age ignition.
Anthenium
I see this is an Old Post. I was just curious if Popeye installed this conversion himself, or the conversion was done before he got the boat. I'm considering the conversion on my 1976 MerCruiser 165, but I've read that some diodes and resistors may need to be soldered in place for this to work right...
jbcurt00
Which is now closed
POPEY hasnt been on iboats in over 2.5yrs, not likely to get or reply to any messages left here., hence the 90day rule.
Please follow the 90day inactive topic rule, as noted in the helpful tip at the top of the page
Status
