silviasurfarn
- Sep 5, 2012
- 4
Hi, newbie here, need help identifying engines in an old Formula 233 from 1970.
Thing is, the owner wants to sell off the old inline 6's and replace with a single V8. I just might be interested in buying the engines and use for parts, possibly replacement, of my 2 x Mercruiser 160hp 250 CID IL6's from 1968. I believe virtually any Mercruiser 165 IL6 will fit into my boat. The outdrives in my boat are 2 x pre-Alphas (MC 160) with 1.65 gear ratio.
In the Formula there are a lot of things indicating an original installation in 1970 with 2 x Mercruiser 165's and pre-Alphas (trim pumps, alternators, starters, carbs etc) but I suspect the engines and outdrives have been replaced over the years. Today one outdrive is a pre-Alpha from 1980 or so, the other is an Alpha Gen1, and I don't know the ratio but guess/hope it's 1.65. The engines are clearly inline 6's, but the engine blocks are blue, and the covers don't have the Mercruiser logo. I cant find any engine numbers, only cast numbers. I suspect they might be from some old truck or so ? I can't even be certain that they're 165hp, who knows, they might be 200hp in which case the outdrives might even have a 1.84 ratio.
It would be nice to know exactly what kind of engines that are mounted in the Formula. Any ideas ? Cast number is 3994256 GM, and there is some more info on the block: CON 2 ... can't tell ... 4 0 together with a clock (!).
I've enclosed a couple of photos.
