I have a Mercruiser 165 with the Chevy 250ci engine. It had a blown head gasket, warped head and some cracks on the outside of the block. I have repaired all of the above and the engine seems to run good now. The oil is lightly milky due to residual left in the oil pump and lifters. Should I put an hour on it and change it again? Also how can I test the block for internal cracks now that everything is back together. I already had the machine shop check the head and it is fine and the engine deck was less than .001" warped.
Thanks in Advance.
Thanks in Advance.
