i_build
- Apr 24, 2005
- 144
Alpha 1 outdrive. I been running upwards of 190* which I know is high. She is a new purchase. I disconnected the feed hose from the outdrive to the t engine and connected a freshwater hose and she ran cool for a half hour. The hose leading from the outdrive wasn't pumping any water till I sucked on the line and ended up with a mouth full of saltwater. After a half hour on the fresh water hose and temps staying below 150* I shut her off and reconnected the hose from the outdrive and she crept up on temp and I noticed while on the lift she didn't have the constant stream of water coming out of the exhaust bellows. Seemed like it would pulse water and wait 10 seconds and pulse again out of the exhaust bellows. The hose from the outdrive after I primed it seemed to have a steady flow but I don't know if using the freshwater hose compensated for a faulty circulation pump or whether the outdrive wasn't supplying sufficient water. Not sure what to fix? Should the feed line from the drive been as forceful as my freshwater hose? Or is my circulation pump not working and the hose compensated for it? Please advise. Thank you in advance.
