Bought a cherry 1 owner '78 Glastron V195 that had a stuck motor/starter for $500. Perfect otherwise.
Well, motor had about 2 gallons of water in it. Drained it, filled it, put a new starter on it and it was just spinning. Pulled the starter off and noticed the ring gear had removed itself from the flywheel, it's just loose in the bellhousing. I can't see any way of fixing it besides pulling the motor...
So looks like the motor is coming out now. I build classic Chevy's, so I'm very familiar with the Inline 250's (GM stamped on the side too). But this is my first major boat project. I've removed outdrives and what not before.
Looks pretty straight forward, can anyone tell me if I've missed anything? Going to knock it out this weekend and freshen up the motor while it's out. Thankfully our tractor should make quick work of the heavy lifting.
Remove:
Fuel line
Wiring
Motor mounts
Outdrive (6 nuts + trim piston nuts)
Motor
Remove:
Fuel line
Wiring
Motor mounts
Motor
