Nbwilson22
- Jul 13, 2020
- 33
Just picked up a 1986 stingray SVB 198 SS with a mercruiser 190 motor and an alpha one out drive.
bought the boat as is for $500. Motor runs but didn’t move.
P/O had it at a shop where they removed the out drive and basically said. That’s the problem. He didn’t have any more info than that and didn’t want to fix it.
he was running a stainless prop and apparently hit some big stud. The stag is destroyed and the gimbal ring has a arm broken off of it. Trying to figure out what I need to do to get this thing working again.
ive been a car mechanic for 15 years so I understand the mechanical side of things just never worked on boats.
he said the boat would rev up but wouldn’t go forward or reverse after a long day on the water.
The shop had the out drive pulled when I bought it so I can easily tear it apart.
I did check the shift linkage and it does slide the pin on unit out and in.
Considering a new out drive is anywhere from 1600-2500 I’d like to see if I can narrow it to the upper or lower.
As well if there’s anything that can be done about the gimbal rings arm that is broken off. (Is it necessary to replace the whole thing or can I weld it back on?)
