I have a problem with some backfiring while running the boat.It appears to do this after I am running while tubing and misfires/backfires after the
throttle is pushed down to a certain position.The tach or Speedometers do not work.The Temp gauge reads 140'.The marine mechanic says its
the settiment that is on the bottom of the gas tank and misfires through the carb.They adjusted the carb,but still does the same thing.
They also said that the tank needs to be replaced as its steel.
Not sure what to do.
Any help would be great.I am mechanically inclined,but new too boating.
Thanks
Mark
Thanks
Mark
