Mercruiser 2.5 or 3.0 winterization
liusigou
I saw a video pour anti freezen water into engine through hose and without drain it out. Should I drain it out ?
if you dont drain it out, it will bust.
Candy Gramformongo
According to manual #2, using antifreeze after draining is optional but "recommended." If you do use it, you leave it in there.
DeepCMark58A
Properly mixed, spend the $ and use real antifreeze and leave it in for corrosion protection.
Lou C
West Marine has a good article on how to choose the right antifreeze for winterizing based on the lowest temp anticipated in your climate…I used to use their -100 but now mix my own Sierra PG antifreeze using a refractometer. It’s cheaper & just as good & can actually be used as an engine coolant.
Scroll down to the chart where the different products are rated in FREEZE protection not just burst protection.
I mix the Sierra to be good to -30* F with the refractometer. Way more than my lowest temp and in 20 years of using AF I have NEVER had a problem….
