Re: Mercruiser 2003 5.0L ECM 555 base timing procedure
The Seloc manual is not clear because one place it shows n/a for ignition timing specs but another place it says to use a scan tool to put it into service mode to set base timing. But the manual covers many different ignition systems and lumps some of the procedures together. I've found several dicrepancies in the manual for those kinds of reasons. When I check the timing with a timing light it goes right back to just a little to the right (retard) of the mark on the timing cover when moving the distributor either direction. But I do know timing matters because I was a little off when setting the distributor in place and the engine wouldn't idle very well when I turned it all the way in one direction so I put it back on TDC and aligned spark plug terminal #1 in the distributor cap to the rotor and it runs fine no matter how far I turn the distributor in each direction. So it appears to me that the base timing is adjustable but the ECM keeps it in the proper range anyway. If it is adjustable why would it matter if the ECM controls timing anyway? My question is should base timing be adjusted if possible, how and why. Thank you.
