Mercruiser 20ft Mariah taking on water
samm835
At the beginning of season, I had my gimbal bearing, bellows replaced, impeller/oil all done. It does stay in the water and never took on water other than what was brought in after getting out of the lake. I am taking the boat back to mechanic tomorrow, but curious where could water be coming in from since bellows are new? Its not a lot of water but pump does come on once a day or so......but it shouldn't be taking any so I want it fixed. I'm sure mechanic will fix, but I would like to know all ideas prior to his diagnosis. 1993 Mariah Talari 200, mercruiser 350
Bt Doctur
bellow malfunction rubber ring dislodged during drive install, ring not glued in place shift cable bellows trim sender wire entry point corroded transom housing loose/leaking hull drain plug any other thru hull fitting
Rick Stephens
don't forget a 27 year old possibly rotten transom and nothing to do with the mechanic doing a bellow job.
