My 78 Searay with Mercruiser 228 SN 5284523 has run fine for the last 7 years. I unfortunately had a ProPulse composite prop on her and during the first trip out this year the fins spun off on when I went to full throttle. (This has happened before and the prop was replaced for free - but I can't recommend a ProPulse prop for a larger boat). The engine of course over reved and I cut the throttle immediately. I knew what the problem was - and replaced the prop with my old trusty aluminum one I keep on board as a spare. On restart the sound was grinding and I had no propulsion although the prop appeared to be spinning. It would only run for a few seconds and then stop. I restarted several times until the whole thing locked up - the started motor couldn't turn the engine. Just a loud click - no movement.
I've got the boat back on the trailer and trying to decide what to do. I am a very experienced DIYer for many things, but I've never worked on my boat engine or outdrive. My guess is that something let loose in the sterndrive and I'm very tempted to take get a manual and take it apart. The prop is free turning - in fact it's more than free turning - it seems very loose. Any ideas!
