OK guys,this one is killing me.RH rotation engine.Now the problem: It will not run pass 2500 rpms under load.Had changed out plugs (set at .35),new wires,coil,cap,fuel filter,new carb,fuel tank clean and everything else vent hose!Timing is set at 8 drg BTDC,check it at 3000 rpms and is at around 27 drg.Checked to see if the secondarys are opening,they are.Ran a compression check,all cyl are running 147 to 150 psi.After changing everything,it ran fine for a short run,next day,back to the 2500 deal,check it out again,still doing it.Any help?this engine has about 110 hours on it.
