Mercruiser 260 Spitting oil from engine
CaliFormula
Hello everyone I love this forum and really appreciate everyone’s input. So I had a leaky riser and got water in my oil. I fixed the riser and was doing an oil change to get the oil clean and I noticed oil in my bilge. The oil is spitting out from a threaded hole in the front of the block. And ideas? I’ll try to attach photos and a video.
wrench 3
The hole is there to put a long bolt into to hold up the fuel pump push rod when you're changing the pump. The rest of the time there should be a short bolt in there to plug up the hole.
