Mercruiser 260 Thunderbolt ground wire
jeepking1
Can anyone tell me where this ground wire is supposed to be connected to? It has a small eye on the end (about the same size as the ones on the coil terminal wires). The other end is under one of the mounting bolts holding the box to the riser. It's the wire on top of the cluster under the mounting bolt.
Bt Doctur
I wager a guess it went to the bottom of the dist base.Most dist use a additional ground wire on the bottom of the dist body.
