mercruiser 3.0 130 hp
punthouse
1989 Mercruiser 3.0 130 hp. New plugs, points, timing set, fuel filter, runs great EXCEPT under heavy load such as pulling up a skier. Full throttle gives hesitation. Runs rough enough to make it hard to pull up a heavier skier. Half throttle works well for small skiers but not adults. Thanks for any help.
loadnet
Re: mercruiser 3.0 130 hp
With engine off,<br /><br />- Look straight down inside your carb<br />- have someone pump the throttle lever for you, a couple of times.<br />- you should see a nice steady stream of gas squirting inside there.<br />- if you don't you may need an excellerator pump inside the carb.<br /><br />- you can also check to make sure the carb fuel bowl is filling up all the way. <br />- Needle and seat may be stuck, thus leaving you with a shortage of fuel on demand.
punthouse
Accelerator pump looks good so looks like the carb comes apart. Thanks.
D
DJ
Guest
punthouse,<br /><br />Before you rip into the carb. make sure the timing is advancing.<br /><br />Get a hold of a timing light and see how the timing reacts under acceleration.
Yep,...<br />And you Might want to Check to see if you're getting Good Pressure from the Fuel Pump......<br />And, Did you Change Both Fuel Filters ??????<br />I Think your motor has the little filter in the carb.... As well as the 1 in the Fuel Pump.....
punthouse
A fuel filter in the fuel pump? This is new to me. How is this done. The filter in the carb was clean but did not know of one on/in the pump. Thanks for your time.
Doesn't your fuelpump have a steel bowl on top, held down with a strap clamp... 5/16s or 3/8s" screw head pointing straight up ?????????<br />There's Supposed to be a Creamic, or paper filter under the bowl.......
rodbolt
Hello<br /> that killer little pump filter that no one changes cause ya cant get to it causes a lot of problems. it looks like a little metal can with a strap and a center bolt that is safty wired to prevent loosening. if you break off the bolt cause its steel:) you have to cut the strap. the strap is not availible from mercrusier and the inlet/outlet ports on the new mexican replacement pumps are not clocked like the old inlet/outlet ports so new fittings will be required.I dont design the things I just gotta fix them<br /> good luck and keep posting :)
