alpha-newbe
- May 27, 2025
- 14
Is there a good reference manual or source that specifies the many specs for the 3.0 4 cyl.
I am in the midst of getting initially a non running engine running and things are going pretty well so far. I am looking for the correct idle speed for this engine currently. Also can someone verify that the shifter interrupt switch will not move back and forth if the boat is out of the water and running on muffs.
Thank you for your help.
