JayEll87
- May 16, 2018
- 24
Good day from Scandinavia
I recently purchased a boat with a Mercruiser 3.0 -98 with Alpha one gen 2 sterndrive. I've done full mantenance to alpha and now started with the engine. Main issue at the moment is that it's not charging correctly, recent owner replaced the alternator and things should be good from that point of view but still multimeter shows just 8,8V in both batteries.. and yes both batteries are died and I've not had time to replace them yet as I noticed this issue just two days ago.
Connections seem to be as wiring diagrams show, only difference from alternator side is that I've 2 wires connected to the same "port" in addition to purple wire, but if I've understood correctly this is just an excitation lead so it should not matter. I tried to measure pretty much everywhere but could not get anything over 9V when engine is running idle, also directly from alternator orange lead. Soo, what would this tell to experts? Can battery affect like this or could the alternator be the reason? It has less than 10hrs in it..
