CaliMercruiser3.0
- Aug 8, 2017
- 7
We have a 2005 Bayliner 175 with a mercruiser 3.0 and an alpha one drive. The motor is a new motor with less than 20 hours on it, and was installed by a reputable dealer/repair shop. While running the old motor for many years we never once heard the audible alarm system sound, and never had an issue with the motor turning itself off. While on the maiden voyages with this new motor the engine has shut itself off twice now, the audible alarm system sounded one of those times, and the 20amp ignition fuse has blown 4 times. The first time the engine died and we found out later the ignition fuse had also blown, the alarm did not sound. That time the boat had run fine for about 35 minutes at various rpm's and trim levels. Then while we were cruising across the lake at about 3000rpm it died with no obvious issues going on. The second time we were on the lake for about 2 hours running it at extended times in various rpm ranges and it was running like a top. After cruising for about half a mile at 3500rpm we pulled the throttle all the way back to the neutral position fairly quickly, and the audible alarm sounded immediately. The boat idled for about 5 seconds with the alarm sounding and then it died and we could actually hear the ignition fuse blow at the same time. We immediately checked all fluid levels and looked over the engine, and everything was in good shape and where it should be. We then replaced the ignition fuse, and after turning they key back on the buzzer sounded again and the ignition fuse blew again. We repeated this process two more times. On the fourth try the buzzer went off and the fuse didn't blow. The engine started right up and ran at idle just fine back to the boat dock. Checked everything again after home and the fluids and connections were all good, so we aren't sure where to go with this. After looking at the wiring diagram for our boat we know that our boat doesn't have the oil pressure switch, the water temp switch. or the gear lube level switch, so we have no clue why the buzzer sounded like it did, or why the ignition fuse blew 4 times.
