mercruiser 3.0 block swap compatible years?
fairshopperguy27
I have a 1997 Bayliner 1950 with a cracked block 3.0LX. I have a good 1988 short (bare) block and am wondering if I can swap all internals except the cam from the 97' into the 88' block?
Ayuh,.... I believe the crankshaft changed in 1990, so no, it won't swap,...
Ayuh,.... The crank shaft is different, it won't swap between the blocks, 'n the flywheel is different,....
