Donboating911
- Aug 31, 2018
- 4
Big Big Problem please help..
I've read a lot on here and everyone seem to have so much good ideas and skills..
i have the 1998 1750 LS Capri Ski with the Mercruiser 3.0 Alpha one.
It will start up fine and idle fine as well. It will over heat to around 225 the carb will smoke from the base and and also kind of smell like gas some smoke from side of egine The problem is when i turn off the egine it chokes and shakes violently before shutting down. When this happen i investigated; the big water hose is very hot and feels like no water in it at all, restart the engine again now no air comming from the propeller it used to, not spitting out water either i dont know whats going on im new to the boat community please help..
before this all happen earlier the same day i found out that the gear oil outdrive was low there was nothing in the reservoir on top. I open the top screw of the outdrive and stick a plastic stick in there and there is oil At the opening but at the top reservoir it was completely empty so i top it off at the reservoir.
Also at the same time i got a big bucket fill with running water holes to submerge the outdrive and started the engine. This is when it all started over heating smoking from carb smelling like some gas and choking at shut down
Anyone please help
thankyou so much and god bless
Anyone please help
