Mercruiser 3.0 i4 starter wiring issues
lister
Hi, all so after nearly two years I have my new engine in, and thought i'd wired it all properly.
Unfortunately I had to use the wiring harness from my 84 engine on my 92 engine but we switched the ignition over so it should be good.
The only thing i cant figure out is when i turn the key the gauges come to life, when i turn the key off the gauges drop.
When i turn the key more it cranks the starter motor, the trouble is when i release the key the starter doesn't stop cranking. I have to cut the power to stop it.
I hope its not relevent but I also had to switch over the starter solenoid from a new starter that I know works with this engine. (so i have my 84 starter with a 92 starter solenoid but im sure they are the same and it cranks fine)
Why isnt the starter stopping when I turn the key to off?
lister
No Title
lister
Starter solenoid plunger sticking? from switching it out it seemed very easy to mess that part up!
Bt Doctur
This wire,the heavy yellow/red goes to the small lug closest to the engine . The purple W/ yellow stripe goes to the outer most small lug away from the motor
lister
Thanks, yep mine is like that, but thanks for confirming
Yellow close to the engine, purple with yellow stripe away from the engine
im thinking the plunger when I swapped the solenoids out
lister
No Title
